Message 1 of 6
testing bt openreach modem
I have a bt openreach modem B-Focus. a picture is attached showing the spec plate and all the numbers.
is there a way to test this modem to see if its actually working properly? I mean by testing it some way by connecting it directly to a computer.? is there a web interface in these devices? or can one telnet or anything?
I have searched on google but all I can find is 'what the lights mean'. the lights all look correct but I  can't get internet and I want to make sure the modem is actually doing its job. there's nothing wrong with the rest of my gear. bt-modem2.jpg thanks for any advice.bt-modem.jpg
5 REPLIES 5
Message 2 of 6
Re: testing bt openreach modem
ECI modems are totally locked and are not user accessible. They can be unlocked but it is a non trivial exercise involving the use of a soldering iron.
The Huawei HG612 variant of the modem, however, is extremely trivial to unlock.
What service are you trying to connect to? It won't work with G.Fast.
Message 3 of 6
From an old post try
To make a direct connection from your PC to the modem which will eliminate the router.
Step 1: Remove the homehub/router from the modem
Step2: Connect your pc/laptop into the modem using LAN1 port
Step3: Open network and sharing centre on windows and click set up a new connection or network
Step4: Connect to the internet then click make a new connection Broadband PPPoE
Step5: Username [email protected] and the password as BT
Step6: connect, If it doesn't,keep pressing try again until it does.
Anonymous
Not applicable
Message 4 of 6
Default web address is 192.168.1.1 I believe, some info here.
If you haven't already, a factory reset would be a good place to start.
Message 5 of 6
@Anonymous  That won't work, ECI modems are locked.
Unless, of course, the OP has paid extra for an unlocked one.
Anonymous
Not applicable
Message 6 of 6
Good point well made, I'd forgotten that I unlocked my old HG612 with custom firmware & missed your first post!
As already said, unlocking the ECI looks to be on a whole other level.
https://forum.kitz.co.uk/index.php?topic=11704.0
