Message 1 of 11
Hub DC input question
This is my hub. I want to try a different power supply with it but someone warned me that some BT hubs have a non-standard DC input size meaning not all 12v DC power supplies will have a DC lead that fits - anyone got an idea if my hub has a standard size DC in socket?
10 REPLIES 10
Message 2 of 11
Re: Hub DC input question
Is anyone able to help? Looking for some kind soul with same hub as me to measure the DC plug on the end of the power supply. I need the diameter of the inner stainless steel part of the DC plug and then the diameter of the plastic larger outer bit of the DC plug.
Message 3 of 11
Which model of Hub is it?  Looks like a HH3 but I am not faimiliar enough  with all the models to be sure. If yoou give teh model number it will be much easier to answer.
Message 4 of 11
It’s a smart hub (not smart hub 2)
Message 5 of 11
It's not that easy to measure as it is either 2.1mm or 2.4mm, for what it's worth my money is on the 2.4mm
Message 6 of 11
HH4 and HH5 had different size 12v sockets - I bought an adapter having bought a HH5 on an auction site for nuppence.
Message 7 of 11
@gspearson
Going by post 4 it's an HH6
Message 8 of 11
Do you see why I’m confused here - there’s talk of 2.1mm, 2.4 mm and then I found another thread where someone said it’s 3mm inner diameter.
Message 9 of 11
I think I saw that thread and later he changed his mind - though I cannot remember to what size.
Message 10 of 11
OK found the thread https://community.bt.com/t5/BT-Devices/Smart-Hub-2-DC-plug/m-p/2161511
Seem to day it is 3mm and a Philmore 206
