Message 1 of 7
Hub admin password
I have forgotten the admin password I changed a while back, have tried the override but keeps saying the admin password is incorrect although thought I had changed it a couple of times. The only option I think is to press the reset button on back of hub that I assume will revert to the default password.
What will I lose information wise if do that??
6 REPLIES 6
Message 2 of 7
Re: Hub admin password
It will reset the hub back to factory settings, so you'll lose anything that you've changed
Message 3 of 7
Sorry to be a dummy but like what would I have changed in the hub?
Message 4 of 7
The most obvious is the admin password and probably the wireless password and maybe the hub SSID
Message 5 of 7
If it rtesets to factory settings admin and wireless passwords and SSID would be kept with the admin pasword going back to original one?
Message 6 of 7
If you factory reset the hub then it is back to like new so SSID, admin password and wireless password are back to that shown on the back of hub
Message 7 of 7
Thanks to everyone who replied
