Message 11 of 14
Re: In Smart Hub 2 Manager the 'remove' button beside devices in My Network isn't working?
Hence it is connected and you can't remove it from the list. It is not a means of disconnecting devices.
Message 12 of 14
so how do you disconnect it
Message 13 of 14
Hi @Davidchelmsford   You switch off the device? You can “disconnect” everything by factory resetting the hub.
Message 14 of 14
.....but it will just re-connect again.
