Message 1 of 3
Is the usb port on hub 6 blocked for memory sticks
The usb port on BT homehubs used to allow usb memory sticks to be accessed from file explorer. Cannot do this on Full Fibre Hub 6. Should this be possible?
2 REPLIES 2
Message 2 of 3
Re: Is the usb port on hub 6 blocked for memory sticks
Well it's certainly still available on the SH2 so would expect it to be available on the hub6.
Remember you need to enable SMB1 on your device as it will be disabled by default as it is now deprecated.
Map the drive to 192.168.1.254/usb1
Message 3 of 3
Thank you for that. I wasn’t familiar with SMB1. Have now enabled it and mapped the drive as you suggested and it all works now. That was a quick fix!
