Message 1 of 8
BT8600 - blocked numbers still ring
Why does my handset ring even the the caller is blocked? I thought it would just stay silent.
I can’t find a setting to deal with this.
7 REPLIES 7
Message 2 of 8
BT8600 - base station volume
For Digital Voice I have had to move my BT8600 base station next to the router. This is in a room which is always in use.
For incoming calls, the base station ringer (not the handset) is excruciatingly loud. Is there a way to  reduce the volume? I can’t find one!
Message 3 of 8
Re: BT8600 - blocked numbers still ring
Hi @Ccc329
Welcome to the community.
Is call blocking switched on? Have you had a look through the BT8600 userguide?
Chris
Message 4 of 8
Thanks. I didn’t realise it wasn’t enough to block individual numbers. I’m hoping that's cracked it!
Message 5 of 8
No worries, @Ccc329
Let us know if it's worked 🙂
Chris
Message 6 of 8
Re: BT8600 - base station volume
I think I found the setting so should be ok now.
Message 7 of 8
It did!
Message 8 of 8
Thanks for coming back to us with an update @Ccc329
Glad the call blocking is working for you now!
Ali
