Message 1 of 6
Large clear display landline phone
Can anyone advise on landline phones for the elderly please. Require LARGE display adjustable volume and clear buttons.  Already has BT 8500 landline phone but the buttons are very worn and has problems pressing due to arthritis. Preferably with similar setup so as not to confuse.  Answerphone not required just 3 cordless phones. Can anyone help please?
5 REPLIES 5
Message 2 of 6
Re: Large clear display landline phone
Hi @NetteJames and welcome to our community.
Thanks for posting. There are a number of phones that might suit your needs. The BT4500 Big Button  is one that we've used previously.
Cheers
David
Message 3 of 6
Thank you I will explore this one  bu we do not really require ansaphone.  Can the volume turned up and ring time extended?
Message 4 of 6
Hi @NetteJames and thanks for the reply.
There are other phones that might suit. Take a look at the BT Shop . For details on the BT4500 take a look at the userguide .
Cheers
David
Message 5 of 6
I see there is also a BT4600  is this a newer model?
Message 6 of 6
@NetteJames Yes, the BT4600 is the newer model.
Neil
