Message 1 of 2
Network mapping discs by wholehome 3 white discs
Does anyone no how to alter network mapping so I can force devices to connect to certain devices
basically my setup is
main room (plugged in router)
bed3  ( connects to main room )
garage (connects to bed 3
hallway ( connects to main room)
study ( connects to hallway)
bed 1 ( connects to hallway )
this is the ideal set up that works flawless
my issue is that the hallway gets unplugged
(always have the argument to not unplug it )
then the study and bed one connects to main room but under a weak signal causing network issues
I would like to no if I can make study and bed1 connect to hallway  automatically when online
as they don’t seem to correct themselves when a good signal is available until I restart the system  thanks
1 REPLY 1
Message 2 of 2
Re: Network mapping discs by wholehome 3 white discs
There is no way to achieve what you want here, I'm afraid. The Smart Wi-Fi discs and your hub will route wireless devices to whichever disc has the strongest connection, regardless of distance.
