Message 1 of 3
No link to base. Please check base.
This is an old topic.  I got the message on mg BT7610 - Oct 2025.
Comments seemed helpful and I bought a replacement base unit off eBay for £7 + £3 postage.
It turned out that my base unit was not the problem.  Fortunately the sellers had incuded a (tested) transformer/power unit, because that turned out to be my problem.
Replacing the transformer solved the problem.
2 REPLIES 2
Message 2 of 3
Re: No link to base. Please check base.
Hi @Keith2.
Thanks for coming to the community and for letting us know this worked for you.
It’s really helpful to hear how you solved the issue.
Debbie
Message 3 of 3
Thanks for sharing this! I was getting the same “No link to base” message and thought the base was faulty too. I’ll check the power/transformer first before replacing the base.
