Message 1 of 2
Old internal BT box, potentially phone
We are looking to take an internal wall down which has a very old BT box on, most likely phone, who do i contact to find out 1; if its live and 2; for removal and reinstate if its still used
Thank you
1 REPLY 1
Message 2 of 2
Re: Old internal BT box, potentially phone
Hi @Pbliss90.
Thanks for coming to the community.
I'd recommend getting in touch with our customer support team and explaining what you're looking to get removed. They’ll be able to let you know if it’s safe to remove yourself or if an engineer visit is required.
Debbie
