Anonymous
Not applicable
Message 11 of 16
Re: Orange light on hub- can't connect to Internet.
If you're on Halo then you're entitled to a 4g Hub to get you by until they fix the problem.
I had that same fault a month or two back and the cause was external to our property, have you checked the Service Status Page to see if there's a fault in your area. See https://my.bt.com/consumerFaultTracking/public/faults/tracking.do?pageId=31
Anonymous
Not applicable
Message 12 of 16
@Keith_Beddoe
When I had this fault it was just a solid orange light, no blue. Maybe it's different with me being on FTTP?
Message 13 of 16
@Anonymous wrote:
@Keith_Beddoe
Probably so, as you had a modem, which might  be the case here. Could even be an old white Openreach modem plugged into the phone line?
@MarieP
I assume you do not have a direct fibre into your property?
Do you have any other Openreach equipment, like another box with lights on?
What is actually plugged into your phone line?
Message 14 of 16
Did you get this sorted? Having the same issue now and tried everything including using a different hub
Message 15 of 16
You are posting on a 4 year old thread!!!
Orange light means means it is an account type problem rather than a physical problem, you need to call customer services 0330 1234 150
Anonymous
Not applicable
Message 16 of 16
Deleted
