Message 1 of 4
Pair request on my Panasonic Smart TV by a "BT Emitter179" device.
I keep getting a pair request on my Panasonic Smart TV by a "BT Emitter179" device.
I do not own one. I don't even know what this device is. I keep cancelling the prompt but the request keeps
popping up more regularly as time goes on. This has started happening since I swapped out my
ASUS Router for the BT Smart Hub 2.
Can anyone tell me what this is and how to stop it happening?
Ray Pooley
3 REPLIES 3
Message 2 of 4
Re: Pair request on my Panasonic Smart TV by a "BT Emitter179" device.
Nothing to do with BT.
Its a Bluetooth device.
Turn Bluetooth off on the TV.
Message 3 of 4
Ok.
Just a coincidence I guess.
Install a BT Hub and start getting prompts from a BT-xxxxxxx device that I never heard of.
Message 4 of 4
@RayPooleywrote:
Ok.
@RayPooleywrote:
Ok.
BT in this case stands for bluetooth, and as the smarthubs dont have bluetooth, it cannot transmit a pair request, it is a coincidence, perhaps neighbours have a new gadget
