Message 1 of 3
Pairing existing discs
Two of my discs became disconnected from my (3 disc) Whole Home network by being unplugged and moved (by partner). The primary disc that remains connected to the hub is blue and gives a good signal, but struggles to cover a house on three floors. They two other discs wouldn't pair on an ethernet cable into the hub so I used the App to remove them both from the network - they were showing red 'not connected' on the App anyway. I then used a pin to reset both discs to factory settings, then started the 'Add new disc' routine from the App. However, when connected to the hub by ethernet cable (to the correct port) and then connected to power and switched on, I get an initial solid purple light on the disc (meaning powering up) but I don't get any further change, no flashing purple, no flashing blue or solid blue.  I've let this run for an hour and no pairing.  I've tried pushing the Wifi button on the disc, it does make a change, a flashing blue light that lasts about 2-3 minutes and then goes off completely. So no further forward. Both discs behave the same, so I'm thinking it's not the discs. I'm trying to avoid taking down the last disc and trying one of these two errant discs as Primary, because I don't want to lose what internet I still have. Any suggestions as to what's going wrong? And how I can get these two discs to pair to what appears to be a perfectly good hub and now a one disc network.
2 REPLIES 2
Message 2 of 3
Re: Pairing existing discs
how do I pair an existing Disc
Message 3 of 3
I see the instructions for pairing a new disc say don't switch the new disc on until the App instructs you to do so. Also, I think (but am not sure) that you need at some point to press the pairing button on the disc (I assume that's what you mean by the WiFi button) and the pairing button on your hub.
Apologies if you've already done all this, but it's a long time since I paired my 4th Wholehome disc and I can't remember the exact steps required and these are only shown in the Wholehome app and not in the BT printed instructions.
It's odd that you lost connection with these 2 discs just because they were unplugged for a while. If that was normally the case then this would happen whenever there was a power interruption which certainly isn't normally the case.
