Message 1 of 2
Problem with black BT WiFi disk.
Hello,
have had a black BT WiFi disk connected to my home hub 2 for about a year without a problem ,
today I switched it on WiFi disk and it just flashes blue, so done factory reset and put it next to the home hub, done the set up procedure with ethernet lead and got a solid blue light .
 Disconnected Ethernet lead and blue light started flashing again ….also pressed pairing button on both units…still flashing blue light….is the unit faulty ?
thanks.
1 REPLY 1
Message 2 of 2
Re: Problem with black BT WiFi disk.
