Message 1 of 2
Remove addresses from SmartHub2 Connections
I have a number of devices showing as connected to my SmartHub2. Those with addresses assigned via DHCP have a Remove option, but several devices are shown as Static and have the Remove option greyed out.
The Hub acts as the DHCP server IPv4. IPv6 is disabled.
What confuses me is that most of the addresses shown as Static are in fact in the range allocated by DHCP, and also that some addresses which are genuinely fixed IPs are shown with incorrect hostnames, or have multiple entries.
I can see that several of the devices shown are not mine - for example I see an entry for a Huawei phone, I've never owned one.
Is there a method for removing an address which the Hub considers to be Static?
1 REPLY 1
Message 2 of 2
Re: Remove addresses from SmartHub2 Connections
The hub connection list is hopeless, just ignore it. It performs no useful function and is often inaccurate.
If you are really bothered, just factory reset the hub.
