Message 1 of 2
Replacement for BT 600 signal extender
Have a iMac that has to work on hard wired Ethernet cable and I’ve done this through BT 600 signal extender via a hub and the domestic wiring. It worked fine until the extender failed yesterday. No power light and test in other sockets shows it’s the unit.
When I tried  to buy the same unit from BT  but they’re no longer available: I’m looking for an equivalent replacement or, could someone kindly suggest an alternative. Is there a a  Wi-Fi disc solution?
1 REPLY 1
Message 2 of 2
Re: Replacement for BT 600 signal extender
Choose from the TP Link range the speed you require. With or without WiFi
https://www.tp-link.com/uk/home-networking/powerline/
I have a set of the 4220 items, they  work just fine
