Message 1 of 6
query regarding new BT tv box pro
I am awaiting the arrival of a BTbox pro in the next couple of days which I intend to connect via ethernet to smart hub 2. My question is do I connect my tv aerial to the input on the box and then out to tv or aerial straight intoTV?
5 REPLIES 5
Anonymous
Not applicable
Message 2 of 6
Re: query regarding new BT tv box pro
Depends on how you wish to receive your Freeview channels. You can either connect by aerial daisy-chained to the TV or you can select IP mode at setup & have the channels delivered over the Internet. The latter I believe gives you generally better quality on non-HD channels at the expense of losing a few.
Message 3 of 6
@arbeeuk
Personally I'd take the first option and in that way you can record upto 4 programmes at one time versus 2 if in IP mode.
Also I suspect that programme start and end times might work better using the aerial input, not much to confirm my suspicions though.
Message 4 of 6
Thanks for the useful info .
So if I use the IP mode I may lose a few channels but will I be able to still watch them on "normal" tv.
Message 5 of 6
@arbeeuk
Yes of course , you just lose the ability to record them.
Message 6 of 6
Thanks Tim.
