Hello
I have three BT HD voice handsets in the house. One of the three no longer works and I need to replace it . Where and How can I purchase an replace NEW ( not refurbished) handset ?
Cheers
Hi @ICCROWTHER
Welcome to our community.
We do stock a small range of home phones over on our shop page Telephones | Home Phones
Lesley
@ICCROWTHER If that involves rechargeable batteries, it might be worth trying a new set of batteries first, as the ones that come with BT phones are notoriously unreliable.
I assume you mean the BT DV handsets that are directly registered to your BT Hub? If so first try replacing the batteries of the faulty one with some ordinary AAA batteries if you have any. Of course if they are not rechargeable ones do NOT put the handset on the charging base during this changeover. But it's worth, apparently trying this first as the ones supplied with these phones can be unreliable. If it then works then get some replacement rechargeable ones of the correct type.
As landlines rush head first into obscurity you're going to find replacement phones of any ilk impossible to find.
Must you only use DV handsets? I don't have any and prefer to pair my existing 'old' landline phones with the Smart Hub 2 using DV adapters and then plugging these into a mains socket where I wish to use my pbone/s which also includes a cordless DECT phone. Perhaps your needs are different to mine though.
