Message 11 of 23
Re: Replacement router instead of new 2026 EE hub
Thanks for replying, I have been testing the speed to the router wired directly into the laptop using Speedtest. This came out At 850 MB. Bolt when I test the speed with my iPhone 16 pro 3 m away max I can get is 300. Also, I have tested it with my iPad which is only 12 months old and I’m lucky if I get 250 MB on this. also upstairs which in a straight line is only 5 m away but it has to go through plasterboard walls and wooden floor. My son can only get about 120 MB on his brand-new Xbox.
Message 12 of 23
Re: Replacement router instead of Home Hub 6
@Kimberlin There is always someone who doesn't do close reading, is there?
So, let me clarify:
I didn't say TP-Link was made in China, did I,  but that it was a Chinese make, as in it's a Chinese brand. There is nothing wrong with products being made in China, as nearly the whole world is made there (even if it's one part of a product).
Anyway, TP-Link is a budget brand aiming to produce a product quickly with as little support afterwards as possible, as it's costly to do that. This means that firmware upgrades are fewer, if any at all, potentially being a security issue at a later stage. For this reason alone, I do not recommend TP-Link.
If you also care whether it's a European brand, so to support something (relatively) local, then I mentioned Fritz, who have a long history of supporting their oldest products with annual firmware updates, which also introduce new features, hardware-permitting.
UniFi is an American brand and has a very good reputation. DrayTek used to have a good reputation but their focus now is getting products out as quickly as possible with a number of firmware issues being regularly reported. Devolo, which is known for its power line adapters, have recently released a very good and capable router that is worth attention.
All in all, just because Currys sells TP-Link, it doesn't mean that that's the only brand out there. It's a budget brand for a reason, too.
Also, with our homes now being connected to the Internet more than before and relying on that connection big time, I'd personally choose security over price and inflated specs, which TP-Link is good at promoting and taking advantage of - for them, it's all about what the new router's WiFi chip is. But, for your devices to take advantage of the ax standard (for example), they need to be ax, too; so, if most of your devices are in ac standard, there is no point in getting something much better as you won't see the benefits of it at all.
The same applies to WiFi7 - if none of your devices use WiFi7, then there is no point getting that kind of router. Finally, getting a router with a 2.5 gig LAN port so that you can connect to the fibre network, even if your ONT isn't capable of that kind of speed, you won't see the advantages of that.
So, getting a router to be future-proof - who knows what the future will be and what will be become the standard. History shows that it's not always what companies think it will be... Plenty examples of that.
Message 13 of 23
@Edinburgh-wg  and @Kimberlin
Can you please stay on topic. The OP has stated he now has a TP-Link so your debate is not relevant to him.
If you want to continue your debate I'll move your posts to another more relevant board.
Message 14 of 23
@gg30340  Ahhh, with respect, I’ve literally said nothing else on the subject and I’m done with it anyway, I’ve moved on already 🤷‍♂️
Message 15 of 23
Practically everything you can lay your hands on in your home in made in China, especially electricals.
Anonymous
Not applicable
Message 16 of 23
You do realise there's a massive difference between made in China and Chinese made.
Message 17 of 23
@topbrewer
Are the devices you're testing with on the 2.4GHz or 5GHz bands as 5GHz is the much faster but with a lower range?
One thing that's important is to split the bands, ie different names, then you know more of what's going on and some older devices might have difficulty connecting to wifi.
Also the channel they're on can make a difference so sometimes an auto setting for this is not a good idea. There are apps that scan for other wifi signals so you can see what channels might be busy with neighbour's wifi.
With non-ISP routers you have much more choice on how you set things up .
Message 18 of 23
Thanks Tim. The router I have doesn’t seem to be able to split the frequencies, they auto select 2.4 or 5. I’m open to learning how to split them of course.
just an update the to link router hasn’t arrived yet, been delayed until Friday!
Message 19 of 23
You can not split the channels on the newer BT hubs so I would think it will be the same on the newer EE hubs.
Message 20 of 23
Thanks for confirming Sage. Hopefully I can on the new TP Link I’ve purchased
