Message 21 of 23
Re: Replacement router instead of new 2026 EE hub
Tp link router coming tomorrow, also did a speed test on firestick that shows 5 ghz channel in use, 186 mbs.
only 5 m away in line of sight as well.
really disappointed
Message 22 of 23
Hi all, Well, new router is plugged in many thanks for everyone’s helping getting it set up. It was very easy through the app. I am now pulling 650mb
vast improvement from bt home hub !
Message 23 of 23
Hi @topbrewer
It's great to hear that you're getting much better speeds than you had with your previous hub.
Thanks for keeping us updated.
Chris S
