Message 1 of 2
Site2site VPN BT Smart Hub options
Hi
I currently have BT business with Smarthub2. I am looking to have a site2site vpn which will be required from router not end client. It appears the smarthub is not capable if anyone has any reccomendations to replace the smarthub with a capable router or has an alternate method that has worked e.g keeping the smart hub and putting a vpn router behind it.
Any info would be great
many thanks
1 REPLY 1
Message 2 of 2
Re: Site2site VPN BT Smart Hub options
@amat1976
Welcome to the BT Residential Customers forum
As you are a business user, please could you post on the BT Business forum at http://business.forums.bt.com/
