Message 1 of 17
Smart Hub 3 Firmware
Does anybody know the latest Firmware on the new Smart Hub 3. Mine is showing r4.26.3-R-1923144-PROD-83002 in the Technical Log page.
But it doesn’t show when it was updated, it just has Not Applicable in that field (N/A showing) so it’s difficult to know the status.
16 REPLIES 16
Message 2 of 17
Re: Smart Hub 3 Firmware
That's the version I have.
Message 3 of 17
Thank you.
Message 4 of 17
Shame the date is missing!
Message 5 of 17
I guess in some ways it is fairly academic as it is not possible to manually update the firmware anyway.
Message 6 of 17
At a guess, I would suspect because it is the initial release.
Message 7 of 17
To be honest the Event Log is also rubbish, it looks exactly the same as TP Link router I had few years ago!
Message 8 of 17
Yes, the old one was far too verbose, this one gives hardly anything. The connection speed figures are useless now too as they don't report the noise margin. One without the other is pointless.
I have fed these and other comments back to BT, but if course no response.
Message 9 of 17
Totally agree with you but I’m surprised that the testers of the software don’t highlight these basic issues. Oh well.
Message 10 of 17
Testers??? 😀😀😀
