Message 1 of 4
Smart Hub - Replacement AC DC Adapter
Does anyone know how I can find out how to get a replacement AC DC Power Cable for Smart Hub - we think it is Type 6  - but the power cable appears to be one that says it is suitable for Smart Hub 4 & 5 Type A.
No broadband at the moment and we're pretty sure the power cable is the reason why - but we can't easily work out what replacement cable is needed online as the one we have seen which looks the right one doesn't look the same on the end of the cable.
Thanks for your help
3 REPLIES 3
Message 2 of 4
Re: Smart Hub - Replacement AC DC Adapter
What happened to the correct power supply for the hub?
Message 3 of 4
Hi @rollingsjane   A well known auction site would be your friend. It will probably be cheaper to buy a hub with adapter included.
Message 4 of 4
"DC Power Cable for Smart Hub - we think it is Type 6"
You can check here
Different types of BT Hub | BT Help
