Hi. We have has full fibre 100 for 2 months now and all good. Suddenly our smart hub 2 has stopped broadcasting a 5ghz signal. All devices connected to 2.4ghz and WiFi analyser does not pick up.5ghz at all only neighbours.
Any ideas how to correct please? I switched off smart back in January and put 5ghz band on 48, all has been good since until today?
Solved! Go to Solution.
If a full factory reset doesn't fix it, report it as faulty to customer services (150) and get a replacement.
Brilliant thank you. I suspect it might need a replacement!! Thanks fir speedy reply
Sorry one other question...as I do think I need replacement router. I have an old smart hub 4 in the cupboard would this work with fttp (full fibre) please in the interim?
I know digital voice won't work but not bothered if I can get back on line?
Yes, if it has a WAN port which I think it has.
