Message 1 of 1
SmartHub 2 and Wifi
I have a SmartHub 2 and 2 complete wifi discs which work well for the most part. However, every few days, the strength of the wifi signal to the discs will drop from "Good" to "Poor". This happens to both discs at exactly the same time, and since they are sited in opposite directions from the SmartHub, I believe that it must be the SmartHub rather than the discs that is causing the problem.
The only way of correcting it is to go to the SmartHub interface and click on the "Restart" button. Is there anything in particular that might be causing this or is it "just one of those things"?
