Message 1 of 6
Turn down blue light on halo
How do you turn down blue light on halo
5 REPLIES 5
Message 2 of 6
Re: Turn down blue light on halo
by halo do you mean the SH2?  if so just go to hub manager 192.168.1.254 into browser address bar and you can turn down or off
Message 3 of 6
Hi @Mussy62   Halo is simply an add on benefit, it doesn’t have any blue lights. Do you mean a) Smart Hub 2, b) Complete WiFi Disc or c) Hybrid Connect?
Message 4 of 6
Hi, @Mussy62 You can change the brightness of the lights on the Smart Hub 2 and Wi-Fi discs independently on the My BT app. Go to Your wi-fi network and then Settings. You can set the lights to off, dim or bright.
Neil
Message 5 of 6
"if so just go to hub manager 192.168.1.254 into browser address bar and you can turn down or off"  "just"!  Well I can't find it either.
Message 6 of 6
Hi @dgovan   Same question, Halo is simply an add on benefit, it doesn’t have any blue lights. Do you mean a) Smart Hub 2, b) Complete WiFi Disc or c) Hybrid Connect?
