Message 11 of 11
Re: USB Printer Connection To BT Hub 2
If your PC is connected to your network and your laptop etc can see the PC connect the printer to that and set it up as a network printer.
As long as the PC and the printer are both switched on the other devices on the network should be able to use it.
Share your network printer - Microsoft Support
