Message 11 of 13
Re: Unable to assign static IP to devices
@evansnp If the SH2 worked as who intended? We all think we know what it should do, but it could well be that someone in the BT team has other ideas for reasons unknown to the rest of the world!
At least you have a working solution, you could always introduce your own router just acting as a switch, DHCP server, and WAP leaving the SH2 for simple routing and DV.
Message 12 of 13
I have been thinking about going back to the Mikrotik for a while, perhaps I’ll do what you suggest I.e. just use the Mikrotik as a switch, and providing DHCP, DNS etc. I’d like to use it for the firewall too, but then it would need to be in router mode, which means double NATing ….. Yuk!
Message 13 of 13
I have never played with a Mikrotik but thought you could use it as a firewall in bridge mode rather than router mode. I may be completely wrong by the way because as I said I have never had a chance to play with one.
