Message 1 of 8
Unauthorised Access
How can I tell if someone has tried to access my router? What would it show as on the activity log?
7 REPLIES 7
Message 2 of 8
Re: Unauthorised Access
Do you mean via the internet externally or from within your home LAN?
If the former, it cannot be accessed. If the latter, they would need to know the wifi password.
Perhaps if you were to expand on your reasons for asking we might be able to help further.
Message 3 of 8
Someone trying to access externally, like someone who had set up networks in the past
Message 4 of 8
The hub cannot be accessed externally.
Message 5 of 8
Even by someone who has set up networks?  He has in the past access and switched stuff off
Message 6 of 8
No
Message 7 of 8
Did he know your wifi password?
If so you need to change it by logging onto the BT hub management page. You should also change the Admin password while you are at it.
Message 8 of 8
ok will try thanks
