Message 1 of 7
Unauthorised Order on My Account – Urgent Help Needed
Hi everyone, hoping someone can advise.
An order for a digital phone has been placed on my BT account without my permission. The equipment has already arrived, but I did not request it and I have never agreed to any changes to my service.
Because of this unauthorised order, my account is now locked and I can’t manage my services or make any updates until the order completes. This is completely unacceptable.
My Hub does not have a ' green'  socket for a digital phone so it is totally useless
I need the following to be sorted as soon as possible:
  • Cancellation of the unauthorised order
  • A returns label or instructions so I can send the equipment back
  • My account to be unlocked so I can manage my services normally
  • Written confirmation that I will not be charged for the order or the equipment
This is a complaint about an order I did not place. How can I escalate this to a real human advisor who can actually fix it?
Thanks in advance.
6 REPLIES 6
Message 2 of 7
Re: Unauthorised Order on My Account – Urgent Help Needed
you can contact billing using message now in this link or phone CS  03301234150 and they should help you
your post does not go to BT
Broadband | BT Help
Message 3 of 7
Thanks - I got though - Wonderfully BT Human called Dan has helped me ...
Message 4 of 7
"My Hub does not have a ' green' socket for a digital phone so it is totally useless"
Just a comment to clarify this. "Digital phones" do not need digital voice for them to work (the green socket on the hub) - they'll work perfectly well plugged into the older BT master socket or indeed extension sockets.
Similarly, ANY phone, digital or non-digital, will work when plugged into the green socket on the hub, if you do have the digital voice telphone service.
It's another BT naming confusion - using the word "digital" to describe two different things.
Message 5 of 7
Thank you for this, chrisjp. It’s honestly so confusing why they send out unsolicited loan equipment i.e. digital voice phone. It’s a real pain having to organise BT to send packaging to send it back, or risk being charged for equipment I never even ordered.
Message 6 of 7
Sounds like it was a DV order so will need to be switched some other time instead
Message 7 of 7
Digital Voice phones are not loaned, they are not required to be returned.
