Message 1 of 3
How to increase the number of rings before answerphone kicks on a series 8500 BT home phone
I've finally worked out how to increase the number of rings before the answerphone kicks on my 8500 series BT landline phone:
Click on Menu;
Click 'select' on the first option: answer phone
use the down arrow to: settings; select OK
arrow down to Ans. &record; select OK ( you may have to select this option twice)
It now shows: "answer delay"; now use the right arrow to increase the number of rings up to a max of 10 rings and select Save.
Its taken me several hours of searching BT and google to resolve that issue.  😀
2 REPLIES 2
Message 2 of 3
Re: How to increase the number of rings before answerphone kicks on a series 8500 BT home phone
Hi @Dave1000, thanks for taking the time to post this information as it will be useful to others in the future.
Cheers
John
Message 3 of 3
Also works on a BT2600 v2 !
Thank you !
