Message 1 of 3
Using BT Hybrid Connect with Dual WAN router
Hi, I have just received the BT Hybrid Connect device which is used if the main BT broadband is down. The hybrid connect device uses the mobile network to provide an Internet connection and is connected via an Ethernet cable to the router. I have a dual WAN Cisco router (for failover) and wondered if the hybrid connect device will work it? If so, which connection type should I select? I have DHCP, Static IP, PPPoE, PPTP, L2TP and Bridge.
2 REPLIES 2
Message 2 of 3
Re: Using BT Hybrid Connect with Dual WAN router
The hybrid connect only works with the BT Smart Hub.
Message 3 of 3
Hi, thanks for the quick reply and for the clarification.
Cheers.
