Message 1 of 3
WholeHome discs - slow speeds
I’m having the same problem - did you manage to fix it?
Past couple of weeks my internet speed has gone from 38 to 6 at my parents and sisters.
Speed is fine if I connect directly to the router so it’s definitely the discs. They’ve worked so well for about 5 years and I’ve had many family members buy them on my recommendation and that means I’m their tech support!
Any suggestions for help greatly appreciated thanks.
2 REPLIES 2
Message 2 of 3
Re: WholeHome discs speeds very slow
Hi Colliwag - I finally worked out that my problem was different to what I thought.
I used to use the BTHH with my Wholehome discs (worked great - using my iphone and Fast.com to check the speed and it was very close to the 150mb I was paying for).
I then switched broadband provider to Sky (similar 150mb package) , plugged the Wholehome discs in and I was only getting a speed of about 40mb (via iphone / Fast.com). Drove me nuts ! Wrestled with this for days, plugged my laptop direct into the Sky hub and was getting 150mb but only getting wifi of less than  a third of this.
I finally worked out that it wasn't the discs at all - they were fine and pumping out 150mb. My problem was that (for some reason) when I used my phone to check the wifi speed it was giving an inaccurate reading. As I said, the reading was fine when I was using the BTHH but, for some reason, the phone was inaccurately reporting the speed coming from the discs when I switched to Sky.
So, my discs were actually working fine - I suggest that if you are checking the wifi speed at your family's house with a phone, try your laptop to check wifi speed as this may give a very different reading.
Cheers,
Scooby99
Message 3 of 3
Re: WholeHome discs - slow speeds
Exactly the same problem.   FritzBox router WiFi is fine at 80 Mb/s but through BT discs it was 3 Mb/s and sometimes less.
Bought a 3 pack of these disc about 8 years ago.  One failed after a power cut about 12 months ago and was replaced with a 2nd hand one.  And then speed degradation start about 3 months ago.  I'm now ditching them.
Did you find a solution / cure?
