Message 1 of 5
Wi-Fi extender
Hello,
I’ve recently joined bt and I wanted to get a extender as the Wi-Fi isn’t the best in one room.
Ive had a look around and I’m lost as I’ve found a few bt devices but some work with others, and others don’t work with other devices.
I have a bt smart hub 2, I googled if there was a extender that worked with my router and I found a ( bt whole home Wi-Fi disc) I then googled this device and found ( I could be wrong) I need to get two one for the router and one for where the signal is weak.
so my question is, is there a bt extender that 100% works with a bt smart hub 2? Or if I that whole home Wi-Fi disc would work just fine.
thanks for reading. Thank you in advance!!
4 REPLIES 4
Message 2 of 5
Re: Wi-Fi extender
@Jap998
Welcome to this user forum for BT Retail phone and broadband customers.
Have you looked at BT Complete Wi-Fi?
https://www.bt.com/help/bt-halo/what-is-complete-wi-fi-
BT loan these disks, but you can buy a single one from the BT Shop, but they are not cheap
https://www.bt.com/broadband/accessories/
You only need one, as they connect wirelessly to the Smart Hub 2.
If its just one room affected, then a wireless hotspot device would be a much cheaper option.
https://www.tp-link.com/uk/home-networking/powerline/tl-wpa4220-kit/
Message 3 of 5
Re: Wi-Fi extender
Hi,
thabks for getting back to me so quickly!
I think the hotspot device would be the option here. I did have one before with my previous isp, but the ethernet cable bt gave me with the smart hub 2 didn’t fit the hotspot device is there any reason for this would you know?
I don’t want to buy one and have the same problem as I don’t want to have to go and buy another Ethernet cable because the one I have doesn’t fit again.
Message 4 of 5
Re: Wi-Fi extender
Ethernet cables are all the same, so there is no reason why you should have difficulty connecting between the Smart Hub 2 and the hotspot Ethernet port.
Message 5 of 5
Re: Wi-Fi extender
I’d recommend repurposing a router as a wireless point. Doesn’t cost anything if you have an old one.
