Message 1 of 4
Will a BT4600 phone work as a voip phone when the new digital phone system is activated
3 REPLIES 3
Message 2 of 4
Re: Will a BT4600 phone work as a voip phone when the new digital phone system is activated
Just plug into the green phone port on back of the BT smart hub 2 once BT digital voice is activated.
More info in here: Digital Voice FAQs.
Message 3 of 4
@Ayton
Yes, you just plug the base unit into the phone socket on the back of the smart hub 2, and it will work just as before.
Message 4 of 4
Many thanks for your very helpful reply
