Message 1 of 7
can't call my mobile from my landline
When I try and call my mobile from my landline all I get is a continous tone. I can my wife's mobile. My wife can call my mobile
I get the same issue if I dial 150  pr the full numbers.
I have rebooted my router but that did not help. I called the tech help from my mobile and they said there is no fault on the line
6 REPLIES 6
Message 2 of 7
Re: can't call my mobile from my landline
can you call your landline from your mobile?
Message 3 of 7
Check that you have not blocked your home number on your mobile phone or that you have not set your mobile phone only to accept numbers in your contacts list or that it is set not to accept hidden numbers assuming your home phone is set to hide its number.
Message 4 of 7
Hi,
Thanks for responding,
yes, I can call the landline from my mobile.
I also checked the blocked number on my mobile. I don't have any.
Message 5 of 7
Hi,
I have already checked all that.
Message 6 of 7
I have same issue. Can't call from landline but can receive calls.
Message 7 of 7
I stooped and started my phone and its working now
