Message 1 of 3
smart hub 2 , dropping 5ghz
i have a problem where the hub disconnects the 5ghz then forces everything onto 2.4
a reboot of the smart hub then resolves the issue
this seems to be happening quite a lot
any advice ?
2 REPLIES 2
Message 2 of 3
Re: smart hub 2 , dropping 5ghz
Phone CS 150 and report a faulty hub and ask for a replacement
Message 3 of 3
There solution was to turn off 2.4 , I had to insist on a new one ,,they agreed to send another,
