Message 1 of 5
Email syncing issues
Hi
I can’t send emails from my BT email app as it says something about syncing. The issue never resolves and emails sit in Draft or Outbox. I pay £7.50 a month. Please can you advise? Many thanks.
4 REPLIES 4
Message 2 of 5
Re: Email syncing issues
Hi there @jlu
Thanks for coming to the community.
Can you try the steps in the BT Email: Trouble sending or receiving emails? help page to see if you can send an email using webmail to yourself and let me know how you get on?
Thanks 🙂
Leanne.
Message 3 of 5
Thanks Leanne. BT told me yesterday that I needed an iPhone 11 to ensure the App worked properly. I only have an iPhone 10. I’m going back to the browser version and I also need to clear the cache. Thank you.
Message 4 of 5
Set up and use the Apple email app that came with your phone and delete the BTMail app.
Message 5 of 5
Thank you
