Message 11 of 14
Re: Emails slide to oblivion!
The swipe options don’t give such flexibility as you suggest but I have set them to ‘none’ so nothing happens by accident what I did find under ‘threads’ was an option to ‘collapse message when read’ which I’ve switched off in case that’s the culprit!!
Message 12 of 14
Keep us posted if that helps.
Message 13 of 14
I’m not sure which action reported in my previous email  has worked but I have had no further problems (to date!). Thanks for your help.
Message 14 of 14
Thanks for updating the thread @Katrina1.
It's great to hear you have had no further issues.
Katie
