Message 1 of 2
lost emails
I bunch of saved emails in a specific folder have vanished.  They contain important information.
1 REPLY 1
Message 2 of 2
Re: lost emails
A bit more information would help.
Are you using an email app/client or webmail?
If an email app/client which one?
If and email app/client is it set up as an IMAP account or a POP3 account?
When did this happen?
Presumably you have checked the Trash folder and other folders for them?
Have you changed your password in case you have been hacked?
Have you checked your " forwarding" settings incase you were hacked and a forwarding address has been set up?
