Message 1 of 6
Advice on connecting to nearest fibre telegraph pole.
Hi folks,
We currently have copper running from the nearest exchange cab to our property providing a lousy 0.8Mb/s while my neighbour who's connected to a different exchange has fibre to the premises. The telegraph pole on which he takes his fibre is 200 meters from our premises in a neighbouring field while the telegraph pole where I get my copper cable from is 500 meters away. I registered an interest a few years ago and I havn't heard anything for over a year now.  Does anyone have any suggestions on whether I can get cable laid pref with a grant and how do I get Openreach to connect it up? Many thanks in advance.
5 REPLIES 5
Message 2 of 6
Re: Advice on connecting to nearest fibre telegraph pole.
if you are a BT broadband customer then enter your phone number and post results including all the notes
Message 3 of 6
Thanks for the speedy response IMJOLLY,
Please find attached:
PS neighbour is on Newnham Bridge exchange
Message 4 of 6
from the results you are getting the best available although not good.  openreach will not re-route your phone connection just to improve your broadband connection speed.
you can try contacting openreach  https://www.openreach.com/broadband-network/fibre-availability
Message 5 of 6
Appreciate you coming back ImJolly, that is really bad news as this is my most expensive contract and by far the slowest but I need the backup. The interesting fact is that I can get a business grant to implement such a solution however apart from this forum, I can't see anyway to contact BT or OpenReach to discuss a one off cost for implementing said solution
Message 6 of 6
Perhaps contacting BT Business would help.
0800 800 152
