Message 1 of 11
BROADBAND
With our current BT contract we have FIBRE ESSENTIAL Which I think is FTTC
I have looked online for FTTC download speeds and they are either 80mbps, 55mbps or 40mbps.
I have looked at our BT account and we have Fibre essential,  but it says download speed 15mbps with a guaranteed speed of 12mbps
But since we have BT Fibre Essential we should be receiving a guaranteed minimum download speed of 32mbps as it says online!
Is this correct?
10 REPLIES 10
Message 2 of 11
Re: BROADBAND
Fibre Essential is 40 Mb maximum…..like all ADSL/VDSL (FTTC) the speed any individual customer gets depends largely on the distance the customer is from their fibre cabinet (in the case of VDSL/FTTC that’s you ) or the exchange for ADSL customers …for your speed to be 15Mb with a guaranteed 12Mb you must be a significant distance from the ‘fibre’ cabinet.
32Mb is the ‘average customer’  speed on Fibre Essential , the average customer is clearly much closer to their cabinet than you are to yours , that’s why the average speed is useless , the advertising authorities require this completely pointless ‘national average’ speed to be published, but it’s of no help on an individual basis , that’s why you also get a bespoke estimate based on your actual address, someone close to their cabinet getting 40Mb from Fibre Essential  clearly gets better than the 32Mb average , you being a long way from your cabinet gets much less than the 32Mb national BT average, 15Mb  isn’t you being penalised , or getting less than you pay for , or less than what’s really available to you on FTTC , it’s what the service can deliver based on your line length  , thats just physics .
Message 3 of 11
Re: BROADBAND
We are 0.8 mile from the green box cabinet!
Message 4 of 11
Re: BROADBAND
@andreaferns120472  Please expand on your 0.8 of a mile comment? What is your realistic expectation based on the distance you have quoted?
I haven’t read or I can’t remember any previous posts you may or may not have made, but I’m assuming you cannot be connected to full fibre (FTTP)?
Message 5 of 11
Re: BROADBAND
Hello
This is my origional post
Is this correct?
Message 6 of 11
Re: BROADBAND
The graph for how speed falls off with distance is a reverse S shape. (You can look up many examples on the internet).
That distance is about where if falls off dramatically, so I am not surprised the speed appears much lower than you might expect.  Unfortunately, FTTC can be a bit hit and miss in that respect.
Message 7 of 11
Re: BROADBAND
You are around 1.3km away from the cabinet if your 0.8mile guesstimate is accurate,  the 15Mb you get actually puts you 2 to 2.5 km away from the cabinet ,  TBH  you can have no idea if the route the cable actually takes  from your cabinet to your house  is 0.8 mile /1.3km or not , you can’t simply draw a straight line between the two , the cable could take a much different path to the one you assume.
If you were correct about 0.8 miles, then a typical speed for that distance is around 20Mb , so you are not that far off what you actually receive anyway , the point was to show you that the national average speed of 32Mb for Fibre Essential doesn’t mean you are entitled to 32Mb , it’s just that on average, most customers on Fibre Essential nationally get that speed , your actual distance is of no real consequence, if you get the minimum speed that’s guaranteed for your location, 12Mb ,  then 32Mb is an irrelevance
Message 8 of 11
Re: BROADBAND
@andreaferns120472  I read your original post and yet you’ve reposted it? I asked you about your 0.8 mile comment and effectively what your knowledge is in relation to what speeds you should be getting over that distance. You didn’t answer the question because clearly you don’t know. You also didn’t answer whether or not you can be connected to FTTP.
Message 9 of 11
Re: BROADBAND
See graph for what speeds can be expected over distance in ideal conditions with ideal cables/lines. The distance is in km so in miles 0.8miles is 1.3km so your speed in ideal conditions would be about 20Mbps max and that is assuming the cable takes a straight run to the cabinet, which it won't.
Message 10 of 11
Re: BROADBAND
@andreaferns120472
the 32mb speed you quoted is the average speed not a guaranteed speed.  the speed you get is dependant on the distance you are from the street cabinet and unless you can see the cable running all the way from cabinet to your home you have no idea the distance the cable takes to your home
