Anonymous
Not applicable
Message 91 of 95
Re: BT 500 vs 900 vs EE
It depends
If you order 500mbps and above then yes you receive a wifi 6 router with the option of wifi 7 (£10 monthly extra)
Anything less and you'll be expected to keep the SH2.
You can always request a new router as a new EE customer but it's not guaranteed.
Message 92 of 95
@Anonymous
So when I switched from BT to Plusnet using One Touch Switching, PN sent me a brand new version of the SH2…….
Anonymous
Not applicable
Message 93 of 95
BT/EE router's don't work on Plusnet
Try it and see.
Message 94 of 95
@Anonymous
I get it that the EE router won’t work with PN, but the BT SH2 does. I didn’t change speeds either.
I’ve no intention of trying a EE router on Plusnet, why would I? let alone the fact that I don’t have an EE router to try anyway.
Anonymous
Not applicable
Message 95 of 95
If you look on the EE forums there are lots of disappointed swappers who thought they would get a wifi 6 router.
The BT/EE rationale is you only need wifi 6 on its higher speed packages
If you currently have a SH2 on a less then a 500mbps package EE see no need to replace your current router.
