Message 1 of 4
BT Fibre External Box
Hi.
My BT grey duct terminates inside my house. Can BT  terminate the fibre straight into the white wall box, or will I have to have both boxes visible in my hall ?
Mark
3 REPLIES 3
Message 2 of 4
Re: BT Fibre External Box
you will have 2 boxes  first is where the external fibre cable is joined to the internal fibre cable and then the ONT (modem) where you connect your router.  you may be able to persuade installer to use a small cigar shaped CSP to join the cables like I have
ONT  + internal CSPONT + internal CSP
Message 3 of 4
Regardless of where fitted, you need both a CSP and an ONT. The external cable cannot be terminated directly in the ONT.
Message 4 of 4
The only way to have the External Lead In connected directly to an ONT would be to use a Field Fit Connector.
Openreach did use them for a short while but abandoned them years ago as they had a high failure rate.
If the Duct comes up inside they’ll use an Internal CSP. Like in the pic above, although the new ones look slightly different.
