Message 1 of 4
BT Guaranteed Speed Really Low?
Hi,
Currently with Plusnet. I get around 34Mbps down and 4Mbps up.
BT's website is quoting
Broadband
5Mb - 11Mb
Download speed range
Estimated Stay Fast Guarantee 1Mb
Upload speed range 1Mb
I wanted to swap to BT and take advantage of complete WIFI, but the online assistant said that I am likely to get the quoted estimates.
My question is: is this likely to be correct as its like a 30X downgrade.
Thanks for any help
3 REPLIES 3
Message 2 of 4
Re: BT Guaranteed Speed Really Low?
From your post it looks like you are on FTTC and BT are quoting ADSL speeds hence big difference. This is often due to the cabinet being full with waiting list so you cannot get FTTC like you currently have.
Enter your phone number and see.
Message 3 of 4
Yes, currently on FTTC.
On the link posted it didn't indicate a waiting list. "Status: Available" Am I best of just staying with Plusnet?
Thanks for the reply
Edit: I realise Plusnet is a sister company of BT, but the discrepancy worries me if jumping to BT, as Sky/TT all quote values around my current rate
Message 4 of 4
It may be from memory that if you have a current connection the checker shows as available so could you try your address please and see if you get same result.
