Message 1 of 3
BT Hub 2 - Solid Orange Light
Hi
My BT hub has had a solid orange light since this morning. I’ve tried the usual things such as restarting the hub, doing a factory reset, turning the open reach hub on and off but the light is still solid orange. I have called customer services and they don’t know what the issue is so have booked an engineer appointment, the problem is the earliest date is Saturday and as I work from home this is going to cause huge issues.
Posting on here on the off chance that someone may have any other suggestions that I could try?
The package I’m currently on is full fibre 2 in case it’s relevant.
Thanks in advance,
Tia
2 REPLIES 2
Message 2 of 3
Re: BT Hub 2 - Solid Orange Light
if you have FTTP what lights are there on the ONT
should be green like this and no light LOS
Message 3 of 3
Hi @imjolly
Thank you for your response.
Yes those three lights are showing.
