Message 1 of 12
BT Hybrid Connect Not Working
Hello
I have been testing an internet failover, and it failed.
Red flashing light on the 4G box, but it is recognised by my hub.
Status is Ready
Unplug the line to the wall socket and NOTHING.
Everything pushes me to ask here.
Martin
11 REPLIES 11
Message 2 of 12
Re: BT Hybrid Connect Not Working
do you have a good EE mobile signal in your home?  it can take a good few minutes after drop in internet connection for the Hybrid to kick in
do you have the add on Halo 3+ as part of your package?
Message 3 of 12
I have Halo 3, and now after a reset it gets the white circle.
Green, flashing green, flashing blue, blue, sits on that for a while, with access from the hub.
After a couple of minutes drops back to white circles. And the hub loses contact.
Goes from Ready to Modem Disconnected.
Message 4 of 12
Spoiler
Just restarted hub and modem, will test that in a minute
Message 5 of 12
OK had all Ok so pulled the WAN cable and the 4G modem went white and no fail over, just had to wait to get back to fibre.
Message 6 of 12
Just caught it after a restart, solid blue, red, white, in about 1 second
Message 7 of 12
from the Halo terms it would appear you need Halo3+ to get the automatic fall over if you drop internet connection otherwise with Halo 3 you need to contact BT to activate hybrid
https://www.bt.com/help/broadband/learn-about-broadband/bt-halo/what-is-bt-halo-and-how-can-i-get-it...
Message 8 of 12
New modem on teh way
Message 9 of 12
Oh well, new kit, connected OK, then dropped to continual flashing red light, will leave for now and try again later.
Message 10 of 12
OK, it does connect, but internet does not work, and flashing red lights.
