Message 1 of 5
BT Hybrid connect - no EE signal
There is no EE mobile signal in our house, can the hybrid connect work with other networks? Vodafone is a good 4G in the house.
4 REPLIES 4
Message 2 of 5
Re: BT Hybrid connect - no EE signal
No.
Message 3 of 5
No, it will only work with the EE network.
Message 4 of 5
Ah well, another useless piece of technology to gather dust before being thrown out in the next spring clean!
Message 5 of 5
Don't throw it out. You may find that it is only loaned/hired to you and they will want it back at the end of your contract if you move providers.
See link
https://www.bt.com/help/tv/how-to-return-and-recycle-your-bt-broadband-hub-and-bt-tv-box-fo
