Message 1 of 2
Upgrade to FUll Fibre and now noerton says I'm on a public network.Why?
Hi,
I just upgraded to full fibre broadband. Now Norton antivirus says that I'm on a Public network and has blocked certain things (not sure what). Why would this happen, and can I switch the firewall back to a private network or is there something wrong? I'm not sure if there's a security problem or not.
Any ideas welcome.
Regards Steve
1 REPLY 1
Message 2 of 2
Re: Upgrade to FUll Fibre and now noerton says I'm on a public network.Why?
Windows defaults to the public setting everytime it establishes a new connection.  On Windows 11, go into Settings >  Network & Internet > Ethernet or Wi-Fi (depending on what you are using).
