Message 11 of 14
Re: BT Openreach - How do you contact them to rectify address issues?
If the CSP ( grey block on external wall ) and ONT exist , presumably those items were installed as ‘newsites’ , so  a ‘brand new’ property, ( presumably you are the first occupant ) as if it were not ‘new build’ and ‘retro build’ someone must have successfully ordered service for the CSP/ONT to physically exist, so is it effectively a brand new property ?
When ‘new builds’ are provided with Openreach FTTP , it’s in advance of any customer ordering service,  the builder at this point refers to the property by the plot number ( and Openreach install the CSP/ONT using the plot number ) as this is normally quite near occupation ( or at least the owner getting the keys ) the postal address will be known , it’s just less important than the plot number ( as far as OR are concerned ) .
If the developer makes a mistakes registering the address  with the relevant authority including the Royal Mail or changes the relationship between the plot and house number after OR have entered their own data , then this type of discrepancy can affect the ordering process .
What does the Royal Mail show for your postal address and are there any differences to what is shown here
https://www.broadbandchecker.btwholesale.com/#/ADSL/AddressHome
Usually , if the PON light on the ONT is steady green , the ‘plot’ was successfully authenticated, and the ONT serial number is ‘recorded’ within Openreach systems  ( irrespective of any address inconsistencies ) , often using the ONT serial number can help the ISP locate the ‘service’ , you could try making a note of the serial number ( normally on a sticker on the ONT  , but also on the rear of the ONT ) and ask the ISP to use that to locate your address in the OR system.
Message 12 of 14
Thanks, I’ve checked the postal address via the link you provided. When I select the correct address, the message that I get is:
We cannot determine broadband availability at this location. This may be a new address to which connectivity is not yet complete.
The PON light is a static green. I have already provided the serial number of the ONT to BT and they still couldn’t activate the service. I’ve contacted BT again today and they’ve just passed me onto a different department. No one seems to want to take any ownership of the issue. I’m just going in circles.
Message 13 of 14
https://www.openreach.com/forms/fibre-broadband-availability---customer-form
Try filling out this formwize , it’s directly to Openreach so no ISP involvement , a section is ‘ my neighbours can get FTTP but I can’t ‘ , provide as much info as possible .
Message 14 of 14
Amazing! Thank you.
